ISY Portal Geo Fencing
Push/Mobile Notifications
For a comprehensive list of solutions, please peruse this page
Geo Fencing
UD Mobile:
https://wiki.universal-devices.com/index.php?title=UD_Mobile#Geofencing
Other Methods:
If you have used Geo Fencing using MobiLinc, you do need to migrate it either to IFTTT, Locactive (IOS) or Tasker (Android):
  1. On your ISY, create a state variable that will be used to identify if you are Home or Away
  2. Do make sure to configure node server in ISY Portal by following these instructions
  3. On portal, for your ISY, go to Select Tools/Connectivity/IFTTT
  4. Click on Set Key, then Create Key. Close.
  5. Click Add Variable
    1. Choose the variable you just created
    2. Name it "Home"
    3. Set Value to 0
  6. Click Add Variable
    2. Name it "Away"
    3. Set Value to 1
  7. Next to those 2 IFTTT events, click on the small blue arrow. This will give you the URL to trigger each of those.
  8. Use an app to trigger those URLs based on location
    1. On IOS, Locative is a good choice
    2. On Android, Tasker is a good choice. For detailed configuration, please review Integration with Tasker
