Polisy:PG2 Dashboard
Settings Menu
Right
Polisy Configuration
Polyglot Configuration
Backup and Restore Polyglot
ISY Settings
System Menu
Restart Polyglot
Reboot ISY
Self explanatory.
Check for Polisy Updates
Update Polisy
Reboot Polisy
Reboots the whole system.
Shutdown Polisy
Shutdown the whole system.
