HAD Customization: Advanced customization table
Appearance
(Redirected from HAD Advanced custom table)
Custom device table options
- location: Name for a group of devices. (It does not have any relationship with ISY folders)
- List:
- name: Name of the device. Has to match an ISY device name. (Required, unless refreshOpt=="Pgm" or "Var")
- displayname: Use to override the device name displayed. (Default: name)
- control: Use to override the device to control. Can be a scene or another device. (Default: name).
- refreshOpt: Use to control the refresh after a change.
- "Yes": Update only current item. (Default for devices)
- "All": Refresh all devices. (Default for scenes)
- "Pgm": If typeControl=="Pgm", you can use refreshOpt to display the Status of the pgm instead of a device. (Default for programs)
- "Var": If typeControl=="Pgm", you can have a variable be displayed instead
- "No": Do not refresh.
- typeControl: Can be "Dev", "Pgm" or "Var".
- if typeControl=="Dev", this means this is a device or Scene.
- if typeControl=="Pgm"
- program: program name
- OR programId: ID of the program (If ID is specified, page can load faster)
- NOTE: The On button will trigger "Then", Off will trigger "Else".
- if typeControl=="Pgm" and refreshOpt=="Var"
- variable: Name of variable to display
- OR
- varType: 1 for integer, 2 for state
- varId: Id of the variable (If Type and ID are specified, page can load faster)
- if typeControl=="Var"
- variable: Name of variable to control (and display if refreshOpt does not specify otherwise)
- OR
- varMax: Maximum value allowed for the variable. Default=100
- varInc: Increment used for the buttons. Default=1
- varControl: Variable additional control. 0=Disable, 1=Slider, 2=Edit (Future)
- varSliderSnap: Value set for slider will be a multiple of varSliderSnap, Default=1.
- hideControls: "Yes", Useful if you want to hide buttons and dimmers.
- labelOn: Use to override the "On" label with something else
- labelOff: Use to override the "Off" label with something else
Custom device table examples
var deviceList =
{ location: "Standard devices & scenes",
list : [
{ name : "Device1" },
{ name : "Device2" },
{ name : "Device3" },
{ name : "Thermostat1" },
{ name : "Thermostat2" },
{ name : "Scene1" },
{ name : "Scene2" }
{ location: "Devices & scenes examples",
list : [
{ name : "DeviceControlledByScene1", control:"Scene1" }, // Controls via scene, display a specific device (All the table will be refreshed)
{ name : "DeviceControlledByScene2", control:"Scene1", refreshOpt:"Yes" }, // Same, but just this device will be refreshed
{ name : "Device", displayname:"DeviceRenamed" }, // Standard device control and display, but change the displayed name
{ name : "DeviceStatusOnly", hideControls:"Yes" } // Displays the device status only, but hide buttons and sliders
{ location: "Programs and Vars examples",
list : [
{ name : "Pgm with status", typeControl:"Pgm", program:"testPgm", refreshOpt:"Pgm" }, // Controls "program". Status is the program's status
{ name : "Pgm custom labels", labelOn:"-1", labelOff:"+1", typeControl:"Pgm", program:"testPgm" }, // Same, but button labels are changed
{ name : "Pgm Controls Var", typeControl:"Pgm", program:"testVarPgm", refreshOpt:"Var", variable:"testVar" }, // Controls "program", but testVar will be displayed
// Direct variable control example, with slider
{ name : "DirectVar", labelOn:"-10", labelOff:"+10", typeControl:"Var", refreshOpt:"Var", varType:"1", varId:"2", varInc:"10", varMax:"500", varSliderSnap:"10" }
