Troubleshooting Help
MAC OSX
    • Click on the Java tab
  • Close all your browsers
  • Close Java Control Panel
ISY Finder does not find ISY
  • Open a terminal window
Admin Console Hangs
    • BetterTouch App
    • Text Expander App
    • PopClip App
    • Moom Appp
Front Panel LEDs/Lights
  • Boot up sequence:
    • Your router provides DHCP
INSTEON
Z-Wave
Instructional Videos
Error Codes
