Eisy-ui
eisy-ui documentaion.
Background
eisy-ui is our modern web interface which replaced the Admin Console. As of firmware version 6.1.2 the Admin Console is deprecated. Admin Console should only be used if a feature is verified as missing by UD staff. eisy-ui has now has features not contained in admin console, os the admin console may display some data incorrectly.
As of 11/1/2026: The admin console should only be used for "configure" of some advanced insteon device features. As the advanced "configure" has been verified as not working correctly in eisy-ui. Also x10 Devices
This document is a work in progress, and is intentionally sparse as eisy-ui is changing rapidly. The goal of the current documentation is to to answer common question for basic features. For questions about advanced features please ask on our user forum https://forum.universal-devices.com/topic/47042-eisy-ui-is-getting-there-heres-where-we-stand/
All documentation is written for the latest version or eisy-ui which may be in staging.
Plugins
eisy-ui plugins is the new way to install and manage plugins. If installing a plugin for the first time do not use PG3 it is legacy. As of writing this document PG3 Plugins still work with eisy-ui but will be completely migrated at a later date.
Devices and Scenes
Devices
Coming Soon
Protocols
Insteon
Access Global Insteon Settings from Menu > Protocols > Insteon
Access Device level Insteon configuration from the Node's Page by right clicking the device then selecting Configuration in the Context Menu.
Insteon Device types were updated in eisy-ui 1.4.7.
Insteon Device Configurations Options were updated in 1.4.13
Z-Wave
Access Global Z-Wave Settings from Menu > Protocols > Zwave
Access Device Level Z-Wave settings by right clicking the device on the Node's Page > Configuration
The device level page has advanced Device Settings such as:
- User Codes for Door Locks
- Configuration Parameters
Backup/Restore
Z-Wave backup and restore is independent of system backup restore. The Z-Wave backup is included in the System Backup but must be triggered prior to the system backup from the Global Z-Wave Settings Page.
Z-Wave backup restore is separate due to the length of time it can take to restore, and many possible Z-Wave configurations during backup.
Restoration can take 0.5 - 2 min per device. So should only be done when absolutely needed.
Required IoX version 6.1.2_14 or greater. Lower version may have a hanging backup restore dialog. See: https://forum.universal-devices.com/topic/47401-z-wave-backup-never-completes-sort-of/#findComment-409358
Z-Wave Legacy
While some Legacy Z-Wave features are available in eisy-ui they are untested please consider upgrading to a Z-Wave 800.
Supported Dongles: https://www.universal-devices.com/product/protocol-support/
Legacy Z-Wave support was never fully implemented in eisy/Polisy firmware, any early Zooz-700 dongles were implemented using Z-Wave 500 protocols and cannot be migrated. Legacy Z-Wave Backup and Restore was never implemented or tested. Assuming backup could happen, restore would require bump to Z-Wave 800, this is true for Z-Matter dongles also. This bump brings another issue, legacy node addresses are different than the current production Z-Wave. If migration does work the node addresses will change and the nodes themselves would likely have a different shape (properties/commands/etc). So any automations/scenes would likely need to be recreated.
Developer Notes: Lines 1501–1553 in ZWaveProductDriver.java: the entire Backup/Restore menu block is wrapped in a /* -- No backup/restore support in Polisy yet ... */ block comment. The block covers both 300-series (Normal/Full backup submenu) and 500-series (single Backup item), plus the Restore item — all commented out.
Access Global Legacy Z-Wave Settings from Menu > Protocols > Zwave (this is the same path as regular Z-Wave, eisy-ui will route to the current implementation)
Matter
Coming Soon
Zigbee
Coming Soon
Groups / Scenes
eisy-ui has change labels of some things perviously referred to as Scenes. This did not change how scenes function it was a change to name only as previous versions of the user interface used the term Scene for both Groups and Scenes. This caused confusing for both staff and users, so with the new UI the labels have been corrected.
What is a Group and what is a Scene?
- A Group is a group of Devices. Each Device can be a controllers, a responder, or both a controller and responder for the group.
- A Scene defines how responders react when a specific Controller issues a command to the group.
- There can be multiple Scenes in a group, one for each Controller.
- There is a Virtual (device) Controller in every group with the same name/address as the Group.
- The Scene for the Virtual Controller defines what happens when a command is issued from eisy (AdminConsole/Programs/eisy-ui/UD-Mobile) to the group (not what happens if another controller issues a command).
- A device can only be a controller for one Group.
- See this topic for discussion: https://forum.universal-devices.com/topic/47304-no-scenes-in-eisy-ui/#findComment-408693
How do I add/edit Scenes/Groups?
- To add a new group (sometimes referred to as a scene) click the add button at the top of the Nodes Page (Menu > Nodes).
- To add a device to a group right click the device > Add to Group.
- To edit scene links click the group in the node list, this will open the group members page, click the carrot next to any controller to see/edit scene links.
- To remove a device in a group , click the the group in the node list, this will open the group members page, right click the member > Delete.
Intseon i3 Keypad Scenes:
i3 Keypads had a few bug fixes in November of 2026. So IoX build must be 6.1.2_17 or greater.
- https://forum.universal-devices.com/topic/47384-bug-i3-4-button-kpl-showing-1-too-many-nodes/page/2/#findComment-410100
- https://forum.universal-devices.com/topic/47384-bug-i3-4-button-kpl-showing-1-too-many-nodes/#findComment-409265
Automations
Programs
Access Programs in eisy-ui from Menu > Automations > Programs. Programs are included in system backups
Copy/Export
Required eisy-ui version: 1.4.11
Copy or export a program by clicking the Copy Button on the Program's Page
Add/Import
Add or Import a Program for the Program List Page or by right clicking a Program Folder to access the Folder's Context Menu.
Reload All
If nodes are deleted then recreated a reboot is required to "load" the programs into memory after deletion. If using IoX 6.1.2_14 or greater the endpoint /rest/programs/reload works instead of reboot. This feature will be a global setting in a future release.
App Notifications
We are in the process of migrating Notification Creation into eisy-ui. Some processes may be automated in the future so please check back soon.
The preferred method to send notifications to Universal Devices Mobile Apps (UD Mobile) is through plugins. Automatic Creation of Notifications from UD Mobile is currently broken from eisy plugins, we are working on a fix. eisy Plugins can still send Notifications to UD Mobile, the only issue is automatic creation of Notifications. Notifications can still be created from eisy-ui programs
Before starting these examples you should have already installed UD Mobile on you phone and logged into your my.isy.io account.
There are several plugins that support App Notifications.
- Notification
- eisy-app-notify
Notification: The original notification plugin, feature rich notifications and redundancy. Created by a long time trusted Plugin Developer, Jimbo Automates. eisy-app-notify: Simple notification plugin, no configuration, no redundancy, no multiple-account support.
In the following example we will use eisy-app-notify but the process is similar for the Notification Plugin.
Plugin Install
Install the eisy-app-notify plugin (or Notification Plugin) if not already installed.
Click add Plugin form the eisy Plugins Page
Search for the eisy-app-notify plugin
Activate the Plugin License (if not already activated)
Select the Plugin Slot ro use Auto Select, to Install
Notification Program Creation
Create a program that triggers the notification
Click Add (Program) from the Programs Page
Name the Program, "Notification Example" is used in this example
Click the "Add" button in the IF section
Select "Status"
In the Add Status dialog select a node. To follow this an example is is best to use a simple device like a light switch or bulb.
Select the "Status" Property. This way we trigger a Notification when Status is changed
Select the Greater than or equal to operator "≥". This way the notification is triggered for all values.
Select the lowest value (e.g. OFF). This way the notification is triggered whenever the status is greater than or equal to 0 (e.g all values)
Click Add when done.
Click the Add button next to the "Then" Section.
Select Command
In The Add Command Dialog select the "App Notify" Node. This is the Node created by the eisy-app-notify plugin.
Select the "Send Message" Command. This is the command to send a message.
For the parameters select the Content Dropdown
The Content Dropdown will list all notification Templates. Select the UD Mobile Event Template. This template contains variables that work with device status changes, so it is shared with all simple notifications. This template is automatically created in eisy-ui 1.4.14 or greater or may have been created by UD Mobile. If it does not exist see UD Mobile Event Templatein this document for instructions on creating the template.
The command should look like this, press Add.
The program should look like this, Select save
Now Trigger the light switch, you should receive a notification in UD Mobile.
Notification Templates
The UD Mobile event template is automatically created in eisy-ui 1.4.14 or greater.
If the Template does not exist it can be created by addind a new Notification Template with these exact parameters. This will instruct the Program to show the name of the Node that triggered the Program in the Subject. The Date, Time and Event in the Body.
Name: UD Mobile Event Template
Subject: ${sys.node.#.name}
Body: ${alert.date} ${alert.time} Event ${alert.event}
