ISY-99i Series INSTEON:Temperature Alert Program
Appearance
Temperature Cold
These programs Wait 5 minutes so if the Temperature is fluctuating is doesn't keep sending Notifications. The Temperature has to remain above or below the set point for 5 minutes.
If
Then
Wait 5 minutes
Send Notification to All
Run Program 'Temperature Warm' (Else Path)
Else
Cold = True
Warm = False
Temperature Warm
If
Then
Wait 5 minutes
Run Program 'Temperature Cold' (Else Path)
Else
Warm = True
Cold = False
These programs run when the temperature crosses the threshold. This example uses 32F. When the program in the If statement is True it means a Notification has already been sent and this program will quit.
Weather Cold
If
Module 'Climate' Temperature < 20 °F
And Program 'Temperature Cold' is False
Then
Run Program 'Temperature Cold' (Then Path)
Else
When the temperature falls
Only runs if it was warm during last check
Weather Warm
If
Module 'Climate' Temperature >= 20 °F
And Program 'Temperature Warm' is False
Then
Run Program 'Temperature Warm' (Then Path)
Else
When it warms
Only runs if it was cold during last check
Download these programs: Temperature Alerts.zip
