ISY Developers:API:Soap
Appearance
SOAP API calls
ISY_Developers : API : Soap
AddDDNSHost
- Registers and DDNS host with the associated IP
AddDDNSHost (string host, string ip)
AddFolder
- Adds a folder
AddFolder (string id, string name)
AddGroup
- Adds a scene/group
AddGroup (string id, string name, flag)
AddNode
- Adds a predefined node for a device with a given address
AddNode (string id, string name, string type, flag)
ClearLastError
- Clears the list of recent errors in ISY
ClearLastError ()
GetCurrentSystemStatus
- Sends the current system status (whole) to the given subscriber
GetCurrentSystemStatus (string SID)
GetDDNSHost
- Returns the currently configured DDNS host
GetDDNSHost ()
GetDebugLevel
- Gets the debug options and current level
GetDebugLevel ()
GetISYConfig
- Returns the current configuration of ISY
GetISYConfig ()
GetLastError
- Gets the list of recent errors in ISY
GetLastError ()
GetNodesConfig
- Returns the configuration of nodes, groups, scenes, and any
GetNodesConfig ()
GetSMTPConfig
- Returns the SMTP Options configured in ISY
GetSMTPConfig ()
GetSceneProfiles
- Gets the profile attributes for responders. Set the controller
GetSceneProfiles (string node, string controller)
GetStartupTime
- Returns a timestamp of when ISY was last started
GetStartupTime ()
GetSystemDateTime
- Returns the current state of ISY
GetSystemDateTime ()
GetSystemOptions
- Returns the options by which ISY is configured
GetSystemOptions ()
GetSystemStatus
GetSystemStatus ()
GetVariable
- Retrieves a variable
GetVariable (type, string id)
GetVariables
- Retrieves all variables of a certain type
GetVariables (type)
InternetAccess
- Enables/Disables port forwarding to ISY on UPnP enabled routers.
InternetAccess (flag)
IsDDNSHostAvail
- Whether or not a DDNS Host is available
IsDDNSHostAvail (string host)
IsSubscribed
- Whether or not the client still holds a subscription to ISY; 0 -
IsSubscribed (string SID)
MoveNode
- Moves a node into a group/scene
MoveNode (string node, string group, flag)
Query
- Queries a node, a scene, or even the whole network
Query (string node, flag)
Reboot
- Reboots the system
Reboot ()
RemoveDDNSHost
- Removes the registered DDNS host. Must use GetDDNSHost
RemoveDDNSHost (string name, string ip)
RemoveFolder
- Removes a folder (permanently) from configuration
RemoveFolder (string id)
RemoveFromGroup
- Removes a Node from a Group
RemoveFromGroup (string node, string group)
RemoveGroup
- Removes a group (permanently) from configuration
RemoveGroup (string id)
RemoveModem
- Replaces the modem attached to ISY and reconfigures devices if
RemoveModem ()
RemoveNode
- Removes a node (permanently) from configuration
RemoveNode (string id)
RenameFolder
- Renames a folder in configuration
RenameFolder (string id, string name)
RenameGroup
- Renames a group in configuration
RenameGroup (string id, string name)
RenameNetwork
- Renames the Network name
RenameNetwork (string name)
RenameNode
- Renames a node in configuration
RenameNode (string id, string name)
ReplaceDevice
- Replaces one device with another (swap)
ReplaceDevice (string node, string NewNode, string firmware)
ReplaceModem
ReplaceModem ()
RestoreDevice
- Restores a specific device from the configuration in ISY
RestoreDevice (string node, flag)
RestoreDevices
- Restores devices from the configuration in ISY
RestoreDevices (flag)
SecuritySystemAction
- Arm/disarm a security system
SecuritySystemAction (string SecAction, string code)
SendHeartbeat
- Immediately sends a heartbeat message to all subscribers
SendHeartbeat ()
SendTestEmail
- Sends a test email. This is used to check SMTP settings.
SendTestEmail (string id)
SetBatchMode
- Causes the system to go to/exit batch mode
SetBatchMode (flag)
SetBatteryDeviceWriteMode
- Enables/disables writing to battery devices automatically
SetBatteryDeviceWriteMode (flag)
SetDebugLevel
SetDebugLevel (string option)
SetLinkingMode
- Changes the way ISY discovers nodes/devices ISY as a controller or
SetLinkingMode (flag)
SetNTPOptions
- Sets NTP Options
SetNTPOptions (string NTPHost, boolean NTPEnabled, int NTPInterval)
SetNodeEnabled
- Enables or disables a node
SetNodeEnabled (string node, flag)
SetNodePowerInfo
- Sets the Power characteristics for a node
SetNodePowerInfo (string node, deviceClass, unsignedInt wattage, unsignedInt dcPeriod)
SetNotificationsOptions
- Sets Notifications Options
SetNotificationsOptions (string MailTo, boolean CompactEmail)
SetParent
- Sets a parent for a node
SetParent (string node, nodeType, string parent, parentType)
SetProgramOptions
- Sets Program Options
SetProgramOptions (boolean PCatchUp, int PGracePeriod, HTMLRole)
SetSMTPConfig
- Sets SMTP Configuration Parameters
SetSMTPConfig (boolean UseDefaultSMTP, string SMTPServer, int SMTPPort, string SMTPUID, string SMTPPWD, string SMTPFrom, int SMTPTimeout, boolean UseTLS)
SetSceneProfile
- Sets the profile attribute for responders. Set the controller
SetSceneProfile (string node, string controller, control, string action)
SetSystemDateTime
SetSystemDateTime (long NTP, int TMZOffset, boolean DST, float Lat, float Long, long Sunrise, long Sunset, boolean IsMilitary)
SetUserCredentials
- Changes the userid and password for a user
SetUserCredentials (string name, string password)
SetVariable
- Sets a variable to the desired value
SetVariable (type, string id, string val)
StartNodesDiscovery
- Puts ISY in discovery (linking) mode Optionally, provide the type
StartNodesDiscovery (string type)
StopNodesDiscovery
- The flag decides the operations (reset, crawl, spider) to be
StopNodesDiscovery (flag)
Subscribe
- Subscribe to Event Stream reportURL To reuse the socket, use REUSE_SOCKET as the value
Subscribe (string reportURL, string duration, string SID)
SynchWithNTS
- Adjusts the clock to NTS
SynchWithNTS ()
Unsubscribe
- Unsubscribe from ISY
Unsubscribe (string SID, int flag)
WriteDeviceUpdates
- Causes device updates to be written to the given node
WriteDeviceUpdates (string node)
