ISY Developers:API:V5:Appendix:Link Definitions
Appearance
ISY_Developers : API : V5 : Appendix : Link Definitions
Link Definitions
<linkdefs>
<linkdef id="I_TSTAT" protocol="I_STD">
<p id="CLISPH" editor="I_CLISPH_DEG"><init val="70.0" uom="F" /></p>
<p id="CLISPC" editor="I_CLISPC_DEG"><init val="74.0" uom="F" /></p>
<p id="CLIFS" editor="I_TSTAT_FAN_MODE"><init val="0" uom="99" /></p>
<p id="CLIMD" editor="I_TSTAT_MODE"><init val="74.0" uom="98" /></p>
</linkdef>
</linkdefs>
| <linkDef> | id | Name of this link definition |
| protocol | Name used to correlate compatibility between controllers and responders | |
| <p> | id | Name of the link parameter. |
| editor | The id of the editor to use for this parameter | |
| <init> | val | The initial value to use for an new link |
| uom | The unit of measure of the initial value |
<linkdefs>
<linkdef id="ASSOC_CMD" protocol="ASSOC_CMD" cmd="true" />
</linkdefs>
| cmd | [True/False] If true then parameters cannot be specified, instead, the link contains a
native command defined in the <accepts> section of the node definition. |
