ISY Developers:API:V5:ZWave
Appearance
ISY_Developers : API : V5 : Z-Wave
Z-Wave
Z-Wave uses some static node server profile files but the node definitions and most of the editors are dynamically created.
For the static files, see Node Server Configuration REST API
REST API
REST is an easy to use URL based command set which allows the developer to communicate with the ISY.
Unless otherwise specified, all REST commands use HTTP GET method.
Notes:
- URL Prefix: /rest/zwave/
/node/<nodeAddress>/def/get
Return the node definition for the specified node.
| nodeAddress | The address of the ISY Node, or 0 to return the node definitions for all Z-Wave nodes. |
e.g.
| /node/ZW010_1/def/get |
