ISY Developers:Java Web Services
/* * These are all generated from the JAX-WS wsimport tool */ import ca.bc.webarts.tools.isy.webservices.DateTime; import ca.bc.webarts.tools.isy.webservices.Empty; import ca.bc.webarts.tools.isy.webservices.UDIServices; import ca.bc.webarts.tools.isy.webservices.UDIServicesPortType; import ca.bc.webarts.tools.isy.webservices.Variable;
import java.util.List; import java.util.Map; import javax.xml.ws.BindingProvider;
public class IsyWSClient
Online Documentation
- Oracle's Java WebServices Tutorial
- Oracle's example WebServices code
- TCPmon[1]- a TCP monitor (written in Java) to monitor ALL TCP packets (ie http and soap)
- UDI Online WSDK Forum
Requirements
- UDI Webservices Developnment kit (UDI WSDK)
- Use the same version as firmware in your device
- Here is the link to Version 3.2.6
- NetBeans
or
- JAX-WS or J2EE SDK
- JAX-WS Documentation
- JAX-WS implementation and tools
- To build a client, you don't need the full J2EE SDK - just JAX-WS to do the WSDL import processing and API.
Process
Basic setup
WSDL Import
Changes to the wsdl file
<wsdl:message name="GetNodesConfigResponse"> <wsdl:part name="nodes" type="uo:nodes"/> </wsdl:message>
<wsdl:message name="GetNodesConfigResponse"> <wsdl:part name="nodes" element="u:nodes"/> </wsdl:message>
These are simple changes.
<!-- RENAMED to add Type with the corresponding element that refers to it below -->
<xsd:annotation>
<xsd:documentation>
Default status info response
</xsd:documentation>
</xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:annotation>
<xsd:documentation>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:annotation>
<xsd:documentation>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
- <wsdl:part name="response" element="u:UDIDefaultResponse"/>
- <wsdl:part name="timeResponse" element="u:UDITimeResponse"/>
- <wsdl:part name="intResponse" element="u:UDIIntResponse"/>
- <wsdl:part name="nodes" element="u:nodes"/>
- <wsdl:part name="configuration" element="u:configuration"/>
- <wsdl:part name="SysStat" element="u:SysStat"/>
- <wsdl:part name="DT" element="u:DT"/>
- <wsdl:part name="SystemOptions" element="u:SystemOptions"/>
- <wsdl:part name="SMTPConfig" element="u:SMTPConfig"/>
- <wsdl:part name="DBG" element="u:DBG"/>
- <wsdl:part name="SceneProfiles" element="u:SceneProfiles"/>
- <wsdl:part name="SubscriptionResponse" element="u:SubscriptionResponse"/>
- <wsdl:part name="LastError" element="u:LastError"/>
- <wsdl:part name="DDNSHost" element="u:DDNSHost"/>
- <wsdl:part name="Var" element="u:Var"/>
- <wsdl:part name="Vars" element="u:Vars"/>
- A patched wsdl is attached udiws30_patched.wsdl
- If you want, do a diff between them to be clear what changes were made
- This will ask you for the location of the wsdl file
- It will also ask for a package to put the resulting code
- I used ca.bc.webarts.tools.isy.webservices
Import the ELK WSDL file
udielkws1.wsdl
file.
Write your Java Application
Create the Service And Port
import ca.bc.webarts.tools.isy.webservices.UDIServices; import ca.bc.webarts.tools.isy.webservices.UDIServicesPortType; ... UDIServices service_ = new UDIServices(); // this classname originally comes from the wsdl file UDIServicesPortType port_ = service_.getUDIServicesPort();
HTTP Basic Authentication
private String isyUsername_ = "admin"; private String isyPassword_ = "yourPasswordHere"; ... /* These calls deal with hashing them into Base64 and putting them into the http header */ Map<String, Object> reqCtx = ((BindingProvider) instance.port_).getRequestContext(); reqCtx.put(BindingProvider.USERNAME_PROPERTY, instance.isyUsername_); reqCtx.put(BindingProvider.PASSWORD_PROPERTY, instance.isyPassword_);
Call Web Services
Sample Java App
//for (Variable variable : isyVars)
// System.out.println(variable.getId() + "=" + variable.getVal());
* @return a list of vars
Debug SOAP Messages With TCPMon
If you want to watch the SOAP messages that are going-to --> and <--coming-back from your ISY, you can use a small (free) Java program called TCPMon.
It acts as a proxy. You point your Web Services app Endpoint Address at TCPMon and TCPMon echoes it to the screen and redirects it onto your ISY. To change your endpoint address, do either:
- edit the WSDL file to point at the TCPMon localPort such as: http://localhost:8080 and re-import it the WSDL to have it regenerate the code
OR
- Update the existing Service class with a new endpoint address
- URL newServiceURL = new URL("http://localhost:8080/services");
- UDIServices tcpMonService = new UDIServices(newServiceURL);
- UDIServicesPortType tcpMonPort = tcpMonService.getUDIServicesPort();
- see http://stackoverflow.com/questions/2046790/change-webservice-endpoint-address-at-run-time
You can even manually type or edit the SOAP message and send it direct to your ISY.
Download it at its Google Code hosted site (http://code.google.com/p/tcpmon).
