Insteon - i3
Behavior Notes
Flags Node Not Queried on Startup
The Flags node is not queried automatically on ISY startup. This is intentional — querying every i3 device's extended properties at startup would add significant delay, especially in installations with multiple i3 devices. Flags node properties will show as unknown until the first manual query is issued (via the Query command on the Flags node or a full device query).
Known Issues
1. Existing i3 Dial, Paddle, and Keypad Users Must Reinstall Device in installed prior to 6.1.2_4 (late Sep 2026)
i3 Dial / i3 Paddle: The primary node was previously assigned the shared DimmerLampSwitchLED nodeDef. In this release it is assigned a new dedicated nodeDef I3DialPaddle which removes the broken BL and LED commands from the primary node (those are now correctly exposed on the Flags node).
i3 Keypad: The load node (SGID 1) was previously assigned KeypadDimmer. In this release it is assigned a new dedicated nodeDef I3KeypadLoad which removes the BL command from the load node (LED Brightness is a global property managed on the Flags node as GV13). Additionally, several new Flags node properties and commands (GV14–GV22) are only available after reinstall because the nodeDef is stored in the ISY database at add-device time.
Because the nodeDef code is stored in the ISY database at add-device time, existing devices will retain the old nodeDef until the device is removed and re-added. The Flags node properties and commands that already existed are unaffected — only the primary/load node nodeDef and newly added Flags node commands require reinstall.
Action required for existing users: Remove and re-add the device to pick up the new nodeDefs.
2. Night LED Brightness Change Requires Night Mode Toggle
When changing the Night LED Brightness (GV18) while the device is already in Night Mode, the new brightness value does not take effect immediately. Night Mode must be turned off and back on again after writing the new value before the device applies the change.
Workaround: After setting Night LED Brightness, send Night Mode Off followed by Night Mode On.
3. RGB LED Color Control Not Available on i3 Keypad
The i3 Dial and i3 Paddle expose individual Red, Green, and Blue LED flags (GV10–GV12 on the Flags node) using the 1F 07 bit register and 20 28–20 2F commands. These are confirmed working on the Dial and Paddle.
The i3 Keypad does not support this. The 1F 07 bits 1, 3, and 4 are marked <Reserved> in the Keypad spec, and the corresponding 20 2x command slots are assigned to unrelated or potentially destructive functions (notably 20 2E is the Lighting Director Controller macro on the Keypad). The per-button LED Flags command (2E 00 XX 11) is write-only with no read-back and an undocumented bit layout.
RGB LED color control cannot be safely implemented for the i3 Keypad until Insteon provides clarification. See proposedI3Changes2.md for the full engineering analysis and open questions submitted to Insteon.
New and Fixed Properties / Commands
All new properties and commands are on the Flags node for each device. The primary/load node changes are limited to nodeDef reassignment (see Known Issue #1 above).
The i3 Keypad Flags node had a prior implementation on a separate branch that is already in master. This release adds new properties and commands on top of that existing implementation without removing any previously working commands, to avoid breaking existing users.
i3 Dial — Flags Node (I3DialFlags)
Properties (Status)
Property ID Type Description
Mode ST Dimmer / Relay Whether the device is in dimmer or relay mode
Program Lock GV1 On/Off Prevents local button from changing device state
Resume Dim GV2 On/Off Returns to previous dim level on turn-on
Relay at Full On GV3 On/Off Relay snaps to full on instead of dim level
Key Beep GV4 On/Off Audible beep on button press
Disable RF GV5 On/Off Disables RF (radio) communication
Dial to Off GV6 On/Off Rotating dial fully counter-clockwise turns device off
Error Blink GV7 On/Off LED blinks on transmission error
Night Mode GV8 On/Off Enables night mode (reduced brightness profile)
Hop Powerline on RF GV9 On/Off Retransmits RF commands over powerline
Red LED GV10 On/Off Red channel of the RGB LED (On = enabled)
Green LED GV11 On/Off Green channel of the RGB LED (On = enabled)
Blue LED GV12 On/Off Blue channel of the RGB LED (On = enabled)
LED Brightness GV13 % (0–100) Global LED brightness, converted from device raw 0–127
Max On Level GV14 % (0–100) Maximum on level the load will reach
Min On Level GV15 % (0–100) Minimum on level before the load turns off
Start On Level GV16 % (0–100) Level the load starts at when turned on
Night Max On Level GV17 % (0–100) Maximum on level in night mode
Night LED Brightness GV18 % (0–100) LED brightness in night mode, converted from device raw 0–127
Night Ramp Rate GV19 Index (0–31) Ramp rate used in night mode
Commands
Command ID Parameters Description
Mode GV0 Dimmer / Relay Set dimmer or relay mode
Program Lock GV1 On/Off Set program lock
Resume Dim GV2 On/Off Set resume dim
Relay at Full On GV3 On/Off Set relay at full on
Key Beep GV4 On/Off Set key beep
Disable RF GV5 On/Off Set disable RF
Dial to Off GV6 On/Off Set dial to off
Error Blink GV7 On/Off Set error blink
Night Mode GV8 On/Off Enable or disable night mode
Hop Powerline on RF GV9 On/Off Set hop powerline on RF
Red LED GV10 On/Off Enable or disable red LED channel
Green LED GV11 On/Off Enable or disable green LED channel
Blue LED GV12 On/Off Enable or disable blue LED channel
LED Brightness GV13 % (0–100) Set global LED brightness
On Level Limits GV14 Max %, Min %, Start % Set max, min, and start on levels in one command
Night Properties GV17 Night Max %, Night LED Brt %, Night RR index Set all night mode properties in one command
i3 Paddle — Flags Node (I3PaddleFlags)
Identical to i3 Dial except:
  • No Dial to Off (GV6) — the Paddle has no rotary dial
All other properties (GV1–GV5, GV7–GV19) and commands are the same as the Dial.
i3 Keypad — Flags Node (I3KeypadFlags)
Properties (Status)
Property ID Type New in this release? Description
Mode ST Dimmer / Relay No Whether the device load is in dimmer or relay mode
Program Lock GV1 On/Off No Prevents local buttons from changing device state
Resume Dim GV2 On/Off No Returns to previous dim level on turn-on
Relay at Full On GV3 On/Off No Relay snaps to full on
Key Beep GV4 On/Off No Audible beep on button press
Disable RF GV5 On/Off No Disables RF communication
Button Lock GV6 On/Off No Locks all physical buttons
Error Blink GV7 On/Off No LED blinks on transmission error
Cleanup Reports GV8 On/Off No Broadcasts cleanup report after local activation
Detach Load GV9 On/Off No Detaches the physical load from button 1
Night Mode GV10 On/Off No Enables night mode
Hop Powerline on RF GV11 On/Off No Retransmits RF commands over powerline
Night LED GV12 On/Off No Enables the night LED indicator
LED Brightness GV13 % (0–100) No (fixed) Global LED brightness, converted from device raw 0–127
Max On Level GV14 % (0–100) Yes Maximum on level the load will reach
Min On Level GV15 % (0–100) Yes Minimum on level before the load turns off
Start On Level GV16 % (0–100) Yes Level the load starts at when turned on
Night Max On Level GV17 % (0–100) Yes Maximum on level in night mode
Night LED Brightness GV18 % (0–100) Yes LED brightness in night mode, converted from device raw 0–127
Night Ramp Rate GV19 Index (0–31) Yes Ramp rate used in night mode
NonToggle Mask GV20 Bitmask (0–15) Yes Buttons configured as non-toggle (momentary)
NonToggle Off Mask GV21 Bitmask (0–15) Yes Non-toggle buttons that send Off instead of On
Trigger Group Mask GV22 Bitmask (0–15) Yes Buttons that trigger group broadcasts
Load Button GV30 1–4 Yes Which button (1–4) controls the physical load
Commands
Command ID Parameters New in this release? Description
Mode GV0 Dimmer / Relay No Set dimmer or relay mode
Program Lock GV1 On/Off No Set program lock
Resume Dim GV2 On/Off No Set resume dim
Relay at Full On GV3 On/Off No Set relay at full on
Key Beep GV4 On/Off No Set key beep
Disable RF GV5 On/Off No Set disable RF
Button Lock GV6 On/Off No Set button lock
Error Blink GV7 On/Off No Set error blink
Cleanup Reports GV8 On/Off No Set cleanup reports
Detach Load GV9 On/Off No Set detach load
Night Mode GV10 On/Off No Enable or disable night mode
Hop Powerline on RF GV11 On/Off No Set hop powerline on RF
Night LED GV12 On/Off No Enable or disable night LED
LED Brightness GV13 % (0–100) No (fixed) Set global LED brightness — previously used setByteProperty; now uses ExtCommandHandler with Group #1 + subcommand 0x07, matching Dial/Paddle behavior
On Level Limits GV14 Max %, Min %, Start % Yes Set max, min, and start on levels in one command (2E 00 00 0D)
Night Properties GV17 Night Max %, Night LED Brt %, Night RR index Yes Set all night mode properties in one command (2E 00 00 12)
NonToggle Masks GV20 NonToggle On mask, NonToggle Off mask Yes Set both non-toggle masks in one command (2E 00 00 08 + 2E 00 00 0B)
Trigger Group Mask GV22 Bitmask (0–15) Yes Set trigger group mask (2E 00 00 0C)
Load Button GV30 1–4 Yes Set which button controls the physical load (2E 00 00 13)
i3 Keypad — Load Node (I3KeypadLoad)
A new dedicated nodeDef I3KeypadLoad is assigned to the load node (SGID 1) of new-layout i3 Keypads. It is identical to KeypadDimmer except:
  • BL command removed — LED Brightness is a global property managed on the Flags node as GV13
  • <ctl /> is empty — the load node has no physical button and cannot initiate a scene
Old-layout i3 Keypads (where SGID 5 is absent) continue using KeypadDimmer unchanged.
Bug Fixes
Device Bug Fix
i3 Dial, i3 Paddle BL command on primary node sent raw percent value (0–100) directly to device which expects raw 0x11–0x7F — LED brightness was set incorrectly Removed BL from primary node; LED Brightness is now GV13 on the Flags node with correct percent↔raw conversion
i3 Dial, i3 Paddle LED command on primary node was write-only with no read-back of current color state Removed from primary node; individual Red/Green/Blue LED flags (GV10–GV12) on Flags node provide read-back and granular per-channel control
i3 Keypad BL command on load node (SGID 1) incorrectly exposed — load node has no physical LED Removed via new I3KeypadLoad nodeDef
i3 Keypad GV13 (LED Brightness) write used setByteProperty which sent a bare 3-byte extended command — did not match the Group #1 + subcommand 0x07 format required by the device Replaced with ExtCommandHandler using the same pattern as Dial/Paddle
