Operation Pane
The Operation Pane is located at the bottom section of the GUI. Depending on the option or node selected on the Tree View it will contain the actions you can perform.
If you selected an INSTEON device or a Scene in the View Pane or the Tree View; the Bottom Pane will show the actions you can perform on the device or the Scene respectively.
Operation Pane
ISY-26 INSTEON: ISY-99i Series INSTEON: User Guide: Main Tab Layout:
