Polisy Developers:ISY:API:Appendix:Status Names
Appearance
Polisy_Developers : ISY : API : Appendix : Status Names
These are the names available for use as IDs for status entries in node definitions (i.e. <st> entries in the <sts> section of the nodedef).
e.g.
<nodeDef id="Thermostat" nls="143">
<sts>
<st id="ST" editor="I_TEMP_DEG" />
<st id="CLISPH" editor="I_CLISPH_DEG" />
<st id="CLISPC" editor="I_CLISPC_DEG" />
<st id="CLIMD" editor="I_TSTAT_MODE" />
<st id="CLIHCS" editor="I_TSTAT_HCS" />
</sts>
</nodedef>
| ID | Description | Polisy Version Introduced |
| ACCX | Acceleration X axis | |
| ACCY | Acceleration Y axis | |
| ACCZ | Acceleration Z axis | |
| ADRPST | Auto DR Processing State | |
| AIRFLOW | Air Flow | |
| ALARM | An alarm occurred (values are different for each device type) | |
| ANGLPOS | Angle Position | |
| AQI | Air Quality Index | |
| ATMPRES | Atmospheric Pressure | |
| AWAKE | Awake | |
| BARPRES | Barometric Pressure | |
| BATLVL | Battery level | |
| BEEP | Beep | |
| BMAN | Deprecated - Use FDUP or FDDOWN | |
| BMI | Body Mass Index | |
| BMR | Basic Metabolic Rate | |
| BONEM | Bone Mass | |
| BPDIA | Blood pressure Diastolic | |
| BPSYS | Blood pressure Systolic | |
| BRT | Brighten | |
| BUSY | Device is Busy | |
| CC | Current Current | |
| CH20 | Formaldehyde CH2O level | |
| CLIEMD | Energy Mode | |
| CLIFRS | Fan Running State | |
| CLIFS | Fan Setting | |
| CLIFSO | Fan Setting Override | |
| CLIHCS | Heat/Cool State | |
| CLIHUM | Humidity | |
| CLIMD | Thermostat Mode | |
| CLISMD | Schedule Mode | |
| CLISPC | Cool Setpoint | |
| CLISPH | Heat Setpoint | |
| CLITEMP | Current Temperature | |
| CO | Carbon Monoxide Level | |
| CO2LVL | CO2 Level | |
| CPW | Current Power Used | |
| CTL | Controller Action | |
| CV | Current Voltage | |
| DELAY | Delay | |
| DEWPT | Dew Point | |
| DFOF | Fast Off | |
| DFON | Fast On | |
| DIM | Dim | |
| DISTANC | Distance | |
| DOF | Off | |
| DOF3 | Off 3 Key Presses | |
| DOF4 | Off 4 Key Presses | |
| DOF5 | Off 5 Key Presses | |
| DON | On | |
| DON3 | On 3 Key Presses | |
| DON4 | On 4 Key Presses | |
| DON5 | On 5 Key Presses | |
| DUR | Duration | |
| ELECCON | Electrical Conductivity | |
| ELECRES | Electrical Resistivity | |
| ERR | Error | |
| ETO | Evapotranspiration | |
| FATM | Fat Mass | |
| FDDOWN | Fade Down | |
| FDSTOP | Fade Stop | |
| FDUP | Fade Up | |
| FREQ | Frequency | |
| GPV | General Purpose Value | |
| GUST | Gust | |
| GV0 | Custom Control 0 | |
| GV1 | Custom Control 1 | |
| GV2 | Custom Control 2 | |
| GV3 | Custom Control 3 | |
| GV4 | Custom Control 4 | |
| GV5 | Custom Control 5 | |
| GV6 | Custom Control 6 | |
| GV7 | Custom Control 7 | |
| GV8 | Custom Control 8 | |
| GV9 | Custom Control 9 | |
| GV10 | Custom Control 10 | |
| GV11 | Custom Control 11 | |
| GV12 | Custom Control 12 | |
| GV13 | Custom Control 13 | |
| GV14 | Custom Control 14 | |
| GV15 | Custom Control 15 | |
| GV16 | Custom Control 16 | |
| GV17 | Custom Control 17 | |
| GV18 | Custom Control 18 | |
| GV19 | Custom Control 19 | |
| GV20 | Custom Control 20 | |
| GV21 | Custom Control 21 | |
| GV22 | Custom Control 22 | |
| GV23 | Custom Control 23 | |
| GV24 | Custom Control 24 | |
| GV25 | Custom Control 25 | |
| GV26 | Custom Control 26 | |
| GV27 | Custom Control 27 | |
| GV28 | Custom Control 28 | |
| GV29 | Custom Control 29 | |
| GV30 | Custom Control 30 | |
| GVOL | Water Volume | |
| HAIL | Hail | |
| HEATIX | Heat Index | |
| HR | Heart Rate | |
| LUMIN | Luminance | |
| METHANE | Methane Density | |
| MODE | Mode | |
| MOIST | Moisture | |
| MOON | Moon Phase | |
| MUSCLEM | Muscle Mass | |
| OL | On Level | |
| OZONE | Ozone | |
| PF | Power Factor | |
| PM10 | Particulate Matter 10 | |
| PM25 | Particulate Matter 2.5 | |
| POP | Percent chance of precipitation | |
| PPW | Polarized Power Used | |
| PRECIP | Precipitation | |
| PULSCNT | Pulse Count | |
| QUERY | Query Device | |
| RADON | Radon concentration | |
| RAINRT | Rain Rate | |
| RELMOD | Relative modulation level | |
| RESET | Reset values | |
| RESPR | Respiratory rate | |
| RFSS | RF Signal Strength | |
| ROTATE | Rotation | |
| RR | Ramp Rate | |
| SECMD | Device secure mode | |
| SEISINT | Seismic Intensity | |
| SEISMAG | Seismic Magnitude | |
| SMAN | Deprecated - Use FDSTOP | |
| SMOKED | Smoke Density | |
| SOILH | Soil Humidity | |
| SOILR | Soil Reactivity | |
| SOILS | Soil Salinity | |
| SOILT | Soil Temperature | |
| SOLRAD | Solar Radiation | |
| SPEED | Velocity | |
| ST | Status | |
| SVOL | Sound Volume | |
| TANKCAP | Tank Capacity | |
| TBW | Total body water | |
| TEMPEXH | Exhaust Temperature | |
| TEMPOUT | Outside Temperature | |
| TIDELVL | Tide Level | |
| TIME | Time | |
| TIMEREM | Time remaining | |
| TPW | Total Power Used | |
| UAC | Valid user access code entered | |
| UOM | Unit | |
| USRNUM | The user access code that associated with the most recent Alarm | |
| UV | Ultraviolet | |
| VOCLVL | Volatile Organic Compound (VOC) level | |
| WATERF | Water Flow | |
| WATERP | Water Pressure | |
| WATERT | Water Temperature | |
| WATERTB | Boiler Water Temperature | |
| WATERTD | Domestic Hot Water Temperature | |
| WEIGHT | Weight | |
| WINDCH | Wind Chill | |
| WINDDIR | Wind Direction | |
| WVOL | Water Volume |
