Polisy Developers:ISY:API:Appendix:Units of Measure
Appearance
Polisy_Developers : ISY : API : Appendix : Units of Measure (UOM)
In the ISY, units of measure include the scientific units of measure as well as custom types. A unit of measure is a numeric type that fully defines a value. Values in square brackets are keywords that may be specified for the unit of measure instead of the numeric value when sending a request to ISY. The ISY will always return the numeric value for the unit of measure.
Polisy
Version ID Description
0 = Unit of measure is unknown
1 = ampere (amp) [amp, ampere]
2 = boolean
3 = btu/h [btuh]
4 = celsius (C) [C, celsius]
5 = centimeter (cm) [cm]
6 = cubic feet
7 = cubic feet per minute (cfm)
8 = cubic meter
9 = day
10 = days
11 = Deadbolt status (See below)
12 = decibel (db) [db]
13 = decibel A (dbA) [dbA]
14 = generic temperature in degree
15 = Door lock alarm (See below)
16 = european macroseismic
17 = Fahrenheit (F) [F]
18 = feet
19 = hour
20 = hours
21 = absolute humidity
22 = relative humidity
23 = inches of mercury (inHg)
24 = inches/hour
25 = index
26 = kelvin (K) [K]
27 = keyword
28 = kilogram (kg) [kg]
29 = kilovolt (kV)
30 = kilowatt (kW)
31 = kilopascal (kPa) [kpa]
32 = kilometers/hour (KPH)
33 = kilowatts/hour (kWH) [kwh]
34 = liedu
35 = liter (l)
36 = lux [lux]
37 = mercalli
38 = meter (m)
39 = cubic meters/hour
40 = meters/sec (m/s)
41 = milliamp (mA)
42 = millisecond (ms)
43 = millivolt (mV)
44 = minute
45 = duration in minutes
46 = millimeters/hour (mm/hr)
47 = month (Jan=1, Feb=2, etc.)
48 = miles/hour (MPH)
49 = - Reserved -
50 = ohm [ohm]
51 = percent
52 = pound
53 = Power Factor
54 = Parts/Million (PPM)
55 = pulse count
56 = The raw value as reported by the device
57 = second
58 = Duration in seconds
59 = seimens/meter
60 = body wave magnitude scale
61 = Richter scale
62 = moment magnitude scale
63 = surface wave magnitude scale
64 = shindo
65 = SML
66 = Thermostat heat/cool state (See below)
67 = Thermostat mode (See below)
68 = Thermostat fan mode (See below)
69 = US gallon
70 = User number
71 = UV index
72 = volt [V, volt]
73 = watt [W, watt]
74 = watts/square meter
75 = weekday (Sun=0, Sat=1, etc.)
76 = Wind Direction in degrees (See below)
77 = year
78 = 0-Off 100-On, 101-Unknown
79 = 0-Open 100-Close, 101-Unknown
80 = Thermostat fan run state (See below)
81 = Thermostat fan mode override
82 = millimeter [mm]
83 = kilometer
84 = Secure Mode 0-Unlock 1-Lock
85 = Ohm Meter (Electrical resistivity)
86 = KiloOhm
87 = cubic meter/cubic meter
88 = Water activity
89 = rotations/Minute (RPM)
90 = Hertz (Hz)
91 = Angle Position degrees relative to North Pole
92 = Angle Position degrees relative to South Pole
93 = Power Management Alarm (See below)
94 = Appliance Alarm (See below)
95 = Home Health Alarm (See below)
96 = VOC Level (See below)
97 = Barrier Status (See below)
98 = Insteon Thermostat Mode (See below) - For Insteon compatibility, should use 67 (Thermostat Mode)
99 = Insteon Thermostat Fan Mode (See below) - For Insteon compatibility, should use 68 (Thermostat Fan Mode)
100 = A Level from 0-255 e.g. brightness of a dimmable lamp
101 = Degree multiplied by 2 (for Insteon compatibility) - For Insteon compatibility, should use 14 (degree)
102 = Kilowatt Second (kWs)
103 = Dollar
104 = Cents
105 = Inches
106 = Millimeters per day
107 = Raw 1-byte unsigned value
108 = Raw 2-byte unsigned value
109 = Raw 3-byte unsigned value
110 = Raw 4-byte unsigned value
111 = Raw 1-byte signed value
112 = Raw 2-byte signed value
113 = Raw 3-byte signed value
114 = Raw 4-byte signed value
115 = Most recent On style action taken for lamp control
116 = Mile
117 = Millibar (mb), typically used in barometric reports
118 = Hectopascal (hPa), typically used in barometric reports
119 = Watt Hour
120 = Inches per day
121 = Mole per cubic meter (mol/m3)
122 = Microgram per cubic meter (ug/m3)
123 = Becquerel per cubic meter (bq/m3)
124 = Picocuries per liter (pCi/l)
125 = Acidity (pH)
126 = Beats per Minute (bpm)
127 = Millimeters of mercury (for blood pressure)
128 = Joule (J)
129 = Body Mass Index (BMI)
130 = Liters per hour
131 = Decibel Milliwatts (dBm)
132 = Breaths per minute
133 = Kilohertz (kHz)
134 = Meters per squared Seconds (m/sec2)
135 = For Apparent Power, VA = Volt-Amp
136 = For Reactive Power, VAR = Volt-Amp Reactive
137 = NTP DateTime - Number of seconds since 1900
138 = Pound per square inch (PSI)
139 = 0 to 360 degrees
140 = Milligram per liter (mg/l)
141 = Newton (N)
142 = US gallons per second
143 = US gallons per minute
144 = US gallons per hour
5.4.2 145 = Text
5.4.2 146 = Reserved for System Editors (Do not use)
5.6.1 147 = XML
5.6.1 148 = Reserved for System Editors (Do not use)
5.6.3 149 = 0-360 Degree of Hue
5.6.3 150 = URL for streaming video/audio/etc.
5.6.4 151 = Unix Timestamp
Special Values
0 - Unlocked
100 - Locked
101 - Unknown
102 - Jammed
1 - Master Code Changed
2 - Tamper Code Entry Limit
3 - Escutcheon Removed
4 - Key/Manually Locked
5 - Locked by Touch
6 - Key/Manually Unlocked
7 - Remote Locking Jammed Bolt
8 - Remotely Locked
9 - Remotely Unlocked
10 - Deadbolt Jammed
11 - Battery Too Low to Operate
12 - Critical Low Battery
13 - Low Battery
14 - Automatically Locked
15 - Automatic Locking Jammed Bolt
16 - Remotely Power Cycled
17 - Lock Handling Completed
19 - User Deleted
20 - User Added
21 - Duplicate PIN
22 - Jammed Bolt by Locking with Keypad
23 - Locked by Keypad
24 - Unlocked by Keypad
25 - Keypad Attempt outside Schedule
26 - Hardware Failure
27 - Factory Reset
27 = Factory Reset
28 = Manually Not Fully Locked
29 = All User Codes Deleted
30 = New User Code Not Added (Duplicate Code)
31 = Keypad Temporarily Disabled
32 = Keypad Busy
33 = New Program Code Entered
34 = RF Unlock With Invalid User Code
35 = RF Lock With Invalid User Codes
36 = Window/Door Is Open
37 = Window/Door Is Closed
38 = Window/Door Handle Is Open
39 = Window/Door Handle Is Closed
40 = User Code Entered On Keypad
41 = Power Cycled
0 - Idle
1 - Heating
2 - Cooling
3 - Fan Only
4 - Pending Heat
5 - Pending Cool
6 - Vent
7 - Aux Heat
8 - 2nd Stage Heating
9 - 2nd Stage Cooling
10 - 2nd Stage Aux Heat
11 - 3rd Stage Aux Heat
0 - Off
1 - Heat
2 - Cool
3 - Auto
4 - Aux/Emergency Heat
5 - Resume
6 - Fan Only
7 - Furnace
8 - Dry Air
9 - Moist Air
10 - Auto Changeover
11 - Energy Save Heat
12 - Energy Save Cool
13 - Away
14 = Program Auto
15 = Program Heat
16 = Program Cool
0 - Auto
1 - On
2 - Auto High
3 - High
4 - Auto Medium
5 - Medium
6 - Circulation
7 - Humidity Circulation
8 = Left & Right Circulation
9 = Up & Down Circulation
10 = Quiet
76 = A 1-360 degree clockwise Wind Direction, 0 indicates no wind
0 = No Wind
90 = East
180 = South
270 = West
360 = North
80 = Thermostat fan running state
0 - Off
1 - On
2 - On High
3 - On Medium
4 - Circulation
5 - Humidity Circulation
6 - Right/Left Circulation
7 - Up/Down Circulation
8 - Quiet Circulation
1 - Power Applied
2 - Ac Mains Disconnected
3 - Ac Mains Reconnected
4 - Surge Detection
5 - Volt Drop Or Drift
6 - Over Current Detected
7 - Over Voltage Detected
8 - Over Load Detected
9 - Load Error
10 - Replace Battery Soon
11 - Replace Battery Now
12 - Battery Is Charging
13 - Battery Is Fully Charged
14 - Charge Battery Soon
15 - Charge Battery Now
1 - Program Started
2 - Program In Progress
3 - Program Completed
4 - Replace Main Filter
5 - Failure To Set Target Temperature
6 - Supplying Water
7 - Water Supply Failure
8 - Boiling
9 - Boiling Failure
10 - Washing
11 - Washing Failure
12 - Rinsing
13 - Rinsing Failure
14 - Draining
15 - Draining Failure
16 - Spinning
17 - Spinning Failure
18 - Drying
19 - Drying Failure
20 - Fan Failure
21 - Compressor Failure
1 - Leaving Bed
2 - Sitting On Bed
3 - Lying On Bed
4 - Posture Changed
5 - Sitting On Edge Of Bed
96 = VOC Level
1 - Clean
2 - Slightly Polluted
3 - Moderately Polluted
4 - Highly Polluted
97 = Barrier Status
0 - Closed
1-99 - Percent Closed (1% = almost Closed, 99% = almost Open)
100 - Open
101 - Unknown
102 - Stopped
103 - Closing
104 - Opening
98 = Insteon Thermostat mode
0 - Off
1 - Heat
2 - Cool
3 - Auto
4 - Fan Only
5 - Program Auto
6 - Program Heat
7 - Program Cool
99 = Insteon Thermostat fan mode
7 - On
8 - Auto
0 - On
1 - Off
2 - Fade Up
3 - Fade Down
4 - Fade Stop
5 - Fast On
6 - Fast Off
7 - Triple Press (On)
8 - Triple Press (Off)
9 - 4 x Press (On)
10 - 4 x Press (Off)
11 - 5 x Press (On)
12 - 5 x Press (Off)
