Polisy Developers:ISY:API:Scene Support:Scenes
Polisy Developers : ISY : API : Scene Support : ISY Scenes
Scenes
The terminology for scene has dual meanings in ISY because in some cases it describes the group (scene) object that contains a set of controller and responder nodes, and in others it describes a single controller (and its links to responders) within the group (scene).
- Controller
- A node such as a light switch that can control responders (e.g. can turn something on/off)
- In some cases, a controller may also be a responder.
- Responder
- A node such as a lamp that can be controlled by a controller (e.g. can be turned on/off)
- Group
- Often referred to as a scene, a group is an object containing a collection controllers and responders. It may contain many controllers and many responders. The group itself acts as a scene controller that also supports native Insteon links.
- Scene
- A single controller linked to one or more responders.
ISY scenes define how controllers control and communicate with responders in the scene. The ISY group itself acts as a controller and therefore also has links to all of the responders in the scene.
https://<isy>/rest/links/groups/39520
<groups>
<group id="39520">
<ctl id="1B 99 17 1">
<rsp>
<link linkdef="I_DIMMER" type="native" node="A B9 44 1">
<p id="OL">
<val uom="51" prec="0">85</val>
</p>
<p id="RR">
<val uom="25" prec="0">27</val>
</p>
</link>
<link linkdef="I_TEMPLINC" type="native" node="1D 6F 15 1">
<p id="CLISPH">
<val uom="14" prec="0">61</val>
</p>
<p id="CLISPC">
<val uom="14" prec="0">81</val>
</p>
<p id="CLIFS">
<val uom="99" prec="0">8</val>
</p>
<p id="CLIMD">
<val uom="98" prec="0">3</val>
</p>
<p id="CLIEMD">
<val uom="2" prec="0">0</val>
</p>
</link>
<link type="ignore" node="ZW060_1"/>
<link type="default" node="ZW033_1"/>
<link type="default" node="1B 99 17 1"/>
</rsp>
</ctl>
<ctl id="39520">
<rsp>
<p id="OL">
<val uom="51" prec="0">100</val>
</p>
<p id="RR">
<val uom="25" prec="0">31</val>
</p>
</link>
<link linkdef="I_DIMMER" type="native" node="1B 99 17 1">
<p id="OL">
</p>
<p id="RR">
</p>
</link>
<p id="CLISPH">
<val uom="14" prec="0">68</val>
</p>
<p id="CLISPC">
<val uom="14" prec="0">75</val>
</p>
<p id="CLIFS">
</p>
<p id="CLIMD">
</p>
<p id="CLIEMD">
</p>
</link>
<link type="cmd" node="ZW060_1" cmd="CLIMD">
<p id="">
<val uom="67" prec="0">3</val>
</p>
</link>
</rsp>
</ctl>
</group>
</groups>
Link Types
Native
type="native"
A direct link between the controller and the responder (e.g. Insteon links, Z-Wave associations, etc.). (Controller→Responder)
For more information see Native Links
Command
type="cmd"
Same as Default except when the controller sends an On command the ISY sends the command specified in the link to the responder. (Controller→ISY→Responder)
Default
type="default"
Whatever command is sent by the controller is forwarded to the responder by the ISY. (Controller→ISY→Responder)
Ignore
type="ignore"
No link is made between the controller and responder.
Link Management
Unless otherwise specified, all REST commands use HTTP GET method.
Notes:
- URL Prefix: /rest
/links[/groups/<groupId>[/controllers/controllerId[/responders/<responderId>]]]
Returns all the links, or just the links for the specified group, controller and/or responder.
| groupId | The node address of the ISY group (scene) node. If not specified then return all links. |
| controllerId | The ISY node address of a controller in the group. If not specified then return all links for the group. |
| responderId | The ISY node address of a responder in the group. If not specified then return all links for the controller. |
| e.g. |
| /rest/links |
| /rest/links/group/39520/ |
| /rest/links/group/39520/controllers/1B 99 17 1 |
| /rest/links/group/39520/controllers/1B 99 17 1/responders/1D 6F 15 1 |
/links/groups/<groupId>/member/<memberId>/remove
Remove the node from the group. All links to and from this node with other controllers and responders in the group are also removed.
| groupId | The address of the ISY group node containing the node to be removed |
| memberId | The address of the node to be removed |
| e.g. /rest/links/groups/21151/member/ZW017_1/remove |
/links/groups/<groupId>/controllers/controllerId/responders/<responderId>/update/default
Change the link between controllerId and responderId to link type default
| groupId | The address of the ISY group node containing the controller and responder |
| controllerId | The node address of the controller |
| responderId | The node address of the responder |
| e.g. /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/default |
/links/groups/<groupId>/controllers/controllerId/responders/<responderId>/update/ignore
Change the link between controllerId and responderId to link type ignore
| e.g. /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/ignore |
/links/groups/<groupId>/controllers/controllerId/responders/<responderId>/update/linkdef/<linkDefId>[?<p1>.<uom1>=<val1>&<p2>.<uom2>=<val2>&<p3>…]
Change the link between controllerId and responderId to link type native.
| linkDefId | The id of the link definition |
| pN | Nth Parameter name (e.g. 'ol') |
| uomN | Unit of measure of the Nth parameter (e.g. 'seconds', 'uom58') |
| valN | The numeric value of the Nth parameter (e.g. '80', '80.01' etc,) |
| e.g. /rest/links/groups/21151/controllers/1 FA 19 1/responders/A 5E 21 1/update/linkdef/I_STD?ol.percent=85&rr.uom25=30 |
/links/groups/<groupId>/controllers/controllerId/responders/<responderId>/update/linkdef/<linkDefId>/cmd/<command>[/<value>[/<uom>]][?<p1>.<uom1>=<val1>&<p2>.<uom2>=<val2>&<p3>…]
Change the link between controllerId and responderId to link type native with a command. (Controller→Responder)
| command | The command to be used in the link (e.g. 'DON', 'CLISPH', etc.) |
| pN | Nth Parameter name (e.g. 'level') |
Commands may also have an unnamed parameter
| value | The value of the unnamed parameter. |
| uom | Unit of measure of the value of the unnamed parameter |
| e.g. |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/linkdef/ASSOC_CMD/cmd/DON |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/linkdef/ASSOC_CMD/cmd/DON/80 |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/linkdef/ASSOC_CMD/cmd/DON/80/percent |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/linkdef/ASSOC_CMD/cmd/DON?level.percent=80 |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/linkdef/ASSOC_CMD/cmd/DON/80/percent?rate.uom58=0.3 |
/links/groups/<groupId>/controllers/controllerId/responders/<responderId>/update/cmd/<command>[/<value>[/<uom>]][?<p1>.<uom1>=<val1>&<p2>.<uom2>=<val2>&<p3>…]
Change the link between controllerId and responderId to link type command. (Controller→ISY→Responder)
| e.g. |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/cmd/DON |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/cmd/DON/80 |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/cmd/DON/80/percent |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/cmd/DON?level.percent=80 |
| /rest/links/groups/21151/controllers/ZW010_1/responders/ZW017_1/update/cmd/DON/80/percent?rate.uom58=0.3 |
