Using the HAM Weather Irrigation Module
The Basic Idea of this Module
For more in depth discussion of Evapotranspiration, please check out Evapotranspiration and Irrigation.
Irrigation Module's Settings
- Calculation Method - The method used to calculate ETo
- Penman-Monteith: Accurate, but relies on averages of Temperature, Wind speed, and Dewpoint throughout the day. Some users had reported problems with communication to the HAM Weather servers which can cause errors in the averages.
 - Hargreaves-Samani: Less accurate, but relies on Min/Max temperatures alone. These can be acquired during one snapshot at the end of the day. As a result, the calculation is far more robust in the presence of HAM Weather access issues.
- Irrigation Region - adjusts for the differing ET in inland vs coastal areas.
- coastal region, interior plains region
- Absorption Factor/Soil Type - adjusts for the relative efficiency of soil absorption.
- 80% absorption is recommended for level ground. This is a generally accepted industry % absorption for rainfall. Users with steep slopes can apply lower percentages to compensate for runoff.
 - Absorption is applied to both rainfall and irrigation:
- 1) Rainfall .5 inches: Effective rain = 0.8 * .5 = .4 inches
 - 2) Irrigation 0.5 inches: Effective irrifation = 0.8 * 0.5 = .4 inches
- Crop Coefficient/Plant Type - Plant needs are species dependent and defined as ETc = ETo * Kc (Kc = crop coefficient).
- Cool season grasses (Bluegrass, Rye, Fescue) use Kc of 0.8
 - Warm season greasses (Bermuda, Saint Augustine, Zoisya, and Centipede) use a Kc of 0.6.
 - Additional values are provided to encompass a range of plants/trees/gardens.
 - Note: the current Evapotranspiration variable is actually ETc (=ETo * Kc)
- Water Applied per Irrigation Cycle - amount of water the user's irrigation program applies to the soil during each run.
 - Allowable Depletion - how much water is allowed to leave (be depleted from) the soil before the next irrigation cycle.
- Evapotranspiration - approximation of the total amount of water leaving via a combination of soil evaporation and plant transpiration.
 - Irrigation Requirement - amount of water to be applied based on the accumulation of previous day(s) water deficits.
 - Yesterday's Water Deficit - total amount of water that has evapotranspired during a twenty four hour window from the day before.
Irrigation Module's Commands
- Irrigation - Cycle Complete - triggers the module's calculations for after water has been applied.
 - Irrigation - Reset Variables - triggers a reset of the module's Irrigation Requirement variable.
If
        Time is 11:00:00PM
Then
        Set 'Front Yard' On
        Wait  10 minutes
        Set 'Back Yard' On
        Wait  5 minutes
        Set 'Back Yard' Off
Please note: If you are using an EZFlora device you only have to turn off the last station. When you turn on the next station the EZFlora first turns off the current station then turns on the next one. If you use an EZio device you will have to turn off each station before turning on the next one.
Calculating the Station Run Time
In order to replace the water that is lost from the soil your station run times will need to be properly calculated. Each type of emitter/sprinkler has a different amount of water that is being delivered per minute/hour. The calculator linked below can be used to calculate the appropriate run time for each station.
Initialize the Module
After you have installed the Irrigation Module the Irrigation Requirement variable will most likely display zero. You will have to trigger a reset of the module variables to get things going correctly. Below is a walk-thru of the steps to perform this reset. Please note: If its the rainy season it may be difficult to tell if Irrigation Requirement is having an issue, so its recommended this be performed anyways just after the first install of the module.
- In the ISY Admin Console go to the Programs tab.
 - Create the temporary program shown in the example below.
 - Right click on the program in the folder tree and select "Run Then" to reset the module.
 - Go back to the Weatherbug tab.
 - Check again Irrigation Requirement and you should now see a number instead of a zero.
 - Once you have done this initialization process you can delete the temporary program.
If
Then
