ISY-99i Series INSTEON:Electricity
Install
You will find access to purchase and install the module in the Help menu on the ISY Administrative Console.
Common Settings
  • Base Price
Open Auto-DR Settings
Flex Alert Settings
  • Enable Flex your Power in the Configuration tab under Electricity.
    • 60 second polling interval should suffice.
  • Just like any other event, in your programs, you can check the status of Flex Your Power.
    • Enabled = you should cut back on your energy use.
    • Based on Flex your Power status turn on/off your devices/scenes.
Electricity Meter
Currently the ISY Electricity Meter function supports the Brultech ECM-1220 energy monitor. If you have ISY994 Z Series (Zigbee), GEM is also supported.
Functionality
  • Number of Channels
  • Utilization
  • Accumulated Power
  • Voltage
  • Polarized Utilization
  • Current
Use any of the above in your program conditions.
Related Pages
