Common Options
Remove Existing Links
WARNING This procedure assumes that your previous tools have created correct links between devices and there are not half links, dead devices, and other aberrations. In short, if you are certain your previous tools (including manual) have created ALL the links properly (no half links, no dead devices still in links, all databases are clean and defragmented), this method will cut your migration to just a few button clicks and renaming the discovered nodes. On the other hand, if you are not sure this procedure might actually cause you to spend more time just to find the root cause of many unexplained anomalies.
Start Linking
To link devices:
  • Choose this menu option
  • Select the link option.
Link a ControLinc
Figure 9. Link a ControLinc Dialog
2430 Manual
Link a RemoteLinc
Figure 10a. Link a RemoteLinc dialog.
  • Buttons can be added to scenes the same as any other controller.
RemoteLinc FAQs
  1. Remove the RemoteLinc from the ISY.
  2. Factory reset the RemoteLinc.
  3. Re-link the RemoteLinc to the ISY - ensuring that you press the All Off button to exit linking mode when done.
  4. Re-establish your button scenes.
2440 Manual
Link a RemoteLinc2
3.1.17+
  • Put RemoteLinc2 in Programming Mode:
  1. Ensure the on/off switch is in the On position
  2. Press and hold the Set Button at the base of the RemoteLinc2 until the LED starts flashing green (takes about 3 seconds)
  • The Insteon address is on a sticker on the back of the RemoteLinc2.
  • To maintain compatibility with the 4-Scene Keypad an 8-Scene Keypad uses groups 1, 3, 5, 7 for the buttons on the right side of the RemoteLinc2 (B, D, F, H) and groups 2, 4, 6, 8 for buttons on the left of the RemoteLinc2 (A, C, E, G).
2444A2 Manual
Link a Motion Sensor
Add Button to IRLinc Receiver
Adding a button to IRLink
2411R Manual
Create Non-Toggle Links - (Always sends only on/off commands)
  1. Select the "Add Button to IRLinc Receiver in the ISY Link Management pulldown menu
  2. Press & hold the IRLinc Set button for about 5 seconds, then release
    • Blue LED will turn Off
  3. Point your IR remote at IR Receiver, and press the button to be learned
    • Blue LED will begin blinking
  4. Tap IRLinc’s Set button once (to always send an on), or twice (to always send an off)
    • Blue LED will continue blinking
  5. On the ISY, click on Ok to link the learned button to ISY
    • Blue LED will return to on as normal after ISY completes linking
Optional: Factory Resetting your IRLinc
  1. Unlink all the links in you ISY to the IRLinc
  2. Unplug the IRLinc, wait 10 seconds
  3. Press and continue to hold the Set button for 5 seconds while plugging the unit back in, then release
    • About 20 seconds after releasing the Set button, blue LED will flash twice to indicate a successful reset
    • Note: Blue LED may or may not be on during reset
Add Button to IRLinc Transmitter
Adding an IRLink Transmitter
Add Sensor to EZSnSRF
EZSnsRF Wireless Sensor Receiver Quick-Start Guide
Add X10 Device to EZX10RF
Step 8 should read:
8. Click and hold the EZX10RF Set button for 4 seconds to finish the process. The led should return to a steady dim glow.
EZX10RF Wireless Sensor Receiver Quick-Start Guide
Advanced Options
  • This option should normally be left on Automatic which uses a query into the device database to determine the best way of communicating.
Advanced Options
New INSTEON Device
    • A B C or
    • A.B.C
  • Click on “Ok"
Figure 11 New Device Dialog
Link a KeypadLinc
Linking a KeypadLinc
Linking a Motion Sensor
Link an I/OLinc
Linking an I/O Linc
Link a Garage Door Control & Status Kit
Linking a Garage Door Control & Status Kit
Link an IRLinc Transmitter
Linking an IRLinc Transmitter
Link a Thermostat
Linking a Thermostat
Link a TriggerLinc
Linking a TriggerLinc
Link an Leak Sensor
Linking a Leak Sensor
New Scene
Figure 12. New Scene Dialog
