ISY-99i Series INSTEON:Networking:Tasker:GetISYvariables
This is how to get the content of an ISY variable with Tasker - and store the results in Tasker Global Variables.
First, setup the Network Awareness section. This is so you get nice, fast API access on the same LAN as your ISY - but secure remote access (either directly, or via the ISY Portal) while away from home.
Master Variable Retrieval Task
First - a master task that will be called by others... I called mine 'ISY-GetStatus-Var'.
1. 'Anchor' - 'start_request' 2. 'HTTP Get' - Server:Port='%IsyUrl' - Path='%URLPrefix/rest/vars/get/%par1/%par2' - Continue Task After Error='Checked' (If direct and self signed cert, check 'Trust Any Certificate') 3. 'Wait' - 'Seconds'=2 - If %HTTPR eq -1 4. 'Goto' - Type='Action Label' - Label='start_request' - If %HTTPR eq -1 5. 'JavaScriptlet' - Paste the 'Code' from the next box... 6. 'Return' - Value='%varLastVal' - Stop=Checked
The content of the JavaScriptlet is:
var parser = new DOMParser();
var xmlDoc = parser.parseFromString(global('HTTPD'),"text/xml");
var varHeader = xmlDoc.getElementsByTagName("var")[0];
setGlobal("varLastType",varHeader.getAttribute("type"));
setGlobal("varLastID",varHeader.getAttribute("id"));
setGlobal("varLastSet",xmlDoc.getElementsByTagName("ts")[0].childNodes[0].nodeValue);
setGlobal("varLastVal",xmlDoc.getElementsByTagName("val")[0].childNodes[0].nodeValue);
setGlobal("varLastInit",xmlDoc.getElementsByTagName("init")[0].childNodes[0].nodeValue);
Retrieve value using master variable retrieval task
I have a variable I wish to retrieve... 'FR-Temp'. It is a 'State' variable with ID 124. On the Wiki, you can see State variables are type '2'.
This is the task you create to get this variable:
1. 'Perform Task' Name='ISY-GetStatus-Var' - Parameter 1='2' - Parameter 2='124' - Return Value Variable='%var_val' 2. 'Action Popup' Text='%var_val' Timeout='5'
Run the task - you'll get a popup with the current variable.
The Javascript sets variables (global in scope) for the properties of the variable.
%varLastVal - Last returned variable value %varLastInit - Last returned variable Init value %varLastSet - Date and time the variable was last set %varLastID - ID of last returned variable %varLastType - Type of last var (1=Integer, 2=State)
In any other task - you can 'Perform Task' 'ISY-GetStatus-Var' with %par1 being the type, and %par2 being the ID of the variable you need the value of. Then read the values of the call from variables...
