Polisy Developers:ISY:API:Appendix:Node Definitions
Appearance
Polisy_Developers : ISY : API : Appendix : Node Definitions
<nodeDefs>
<nodeDef id="Thermostat" nls="143">
<sts>
<st id="ST" editor="I_TEMP_DEG" />
<st id="CLISPH" editor="I_CLISPH_DEG" />
<st id="CLISPC" editor="I_CLISPC_DEG" />
<st id="CLIMD" editor="I_TSTAT_MODE" />
<st id="CLIHCS" editor="I_TSTAT_HCS" />
<st id="ERR" editor="I_ERR" hide="T" />
</sts>
<cmds>
<sends>
<cmd id="DON" />
<cmd id="DOF" />
</sends>
<accepts>
<cmd id="CLISPH">
<p id="" editor="CLISPH_DEG" init="CLISPH" />
</cmd>
<cmd id="CLISPC">
<p id="" editor="CLISPC_DEG" init="CLISPC" />
</cmd>
<cmd id="CLIMD">
<p id="" editor="T_MODE" init="CLIMD" optional="T" />
</cmd>
<cmd id="QUERY" />
</accepts>
</cmds>
</nodeDef>
</nodeDefs>
| <nodeDef> | id | Name of this node definition (e.g. "Thermostat") |
| nls | NLS key string used to override names of commands, status and other elements. | |
| <st> | id | One of the predefined status names e.g. "CLISPH" |
| editor | The id of the editor to use | |
| hide | (Optional) Set to "T" or "True", hides status in views but is available in program conditions | |
| <sends> | The commands this node can send out. Used for control conditions in ISY programs and scene controllers. | |
| <accepts> | The commands this node accepts. Used for buttons etc. in ISY clients, and actions in ISY programs. | |
| <cmd> | id | Name of a command. |
| <p> | id | Name of a command parameter. A command may have one unnamed parameter, all others must be named. |
| editor | The id of the editor to use for this parameter | |
| init | (Optional) id of the <st> status value this parameter should be initialized and synchronized with. For example, CLISPH is both a status and a command. | |
| optional | (Optional) Set to "T" or "True" if this is an optional parameter | |
| nls | (Optional) NLS key string used to override name of parameter. |
